Easily customize your conference room set-up with GROUP extended cable, a DIN cable. The GROUP extended cable increases the distance from the hub to the camera or speakerphone with a single cable, that can be routed through a conduit for super-clean conference room installations.
Product Description | Logitech GROUP - camera extension cable - 10 m | Cable | Camera extension cable | Length | 10 m | Connector | PS/2 - male | Connector (Second End) | PS/2 - male | Manufacturer Warranty | 2-year warranty |
General | |
Cable Type | Camera extension cable |
Length | 10 m |
Connectivity | |
Connector | 6 pin mini-DIN (PS/2 style) - male |
Connector (Second End) | 6 pin mini-DIN (PS/2 style) - male |
Miscellaneous | |
Included Accessories | Cable management straps |
Compliant Standards | FCC Class A certified, RoHS, VW-1 |
Dimensions & Weight | |
Weight | 278 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
