The Logitech Wireless Headset H820e, combines enterprise-quality wireless audio with superior design elements, making it Logitech's best wireless headset. Interruptions are minimized with a distinct in-call LED light, and muting is intuitive thanks to the on-boom mute button and LED mute indicator light.
Product Description | Logitech Wireless Headset Dual H820e - headset | Product Type | Headset - DECT - wireless | Recommended Use | Computer | Headphones Form Factor | On-ear | Connectivity Technology | Wireless | Wireless Technology | DECT | Sound Output Mode | Stereo | Audio Specifications | Frequency Response 150 - 7000 Hz - Sensitivity 103 dB | Microphone | Boom | Controls | Mute, volume, answer/end | Manufacturer Warranty | 2-year warranty |
General | |
Width | 17.4 cm |
Depth | 5 cm |
Height | 16.5 cm |
Weight | 128 g |
Max Operating Distance | 100 m |
Audio Output | |
Headphones Cup Type | Open |
Frequency Response | 150 - 7000 Hz |
Sensitivity | 103 dB |
Microphone | |
Type | Boom |
Sensitivity | -45 dB |
Frequency Response | 100 - 7000 Hz |
Total Harmonic Distortion (THD) | 10% |
Remote Control | |
Wireless Link | |
Transmission Range | 100 m |
Connections | |
Connector Type | USB (4 PIN USB Type A) |
Miscellaneous | |
Included Accessories | Charging stand |
Cable Details | USB charge cable |
Power | |
Battery | Headphone battery |
Run Time (Up To) | 10 hour(s) |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
