Logitech Harmony Hub
EXCLUSIVE
WORKS WITH ALEXA
£89.98
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • CONTROL IT ALL VIA SMARTPHONE OR TABLET
  • WORKS WITH YOUR ENTIRE UNIVERSE
  • UNLIMITED ACTIVITIES
  • Type: Central controller
  • Compatible With: Alexa
  • Stock Status: In Stock
Product codes
Harmony Hub turns your smartphone or tablet into a universal remote, giving you control over your home entertainment and smart home devices. You can change channels and volume, program favorites, control lights and other smart devices, and build multi-device experiences called Activities. Plus you can do it all even when you're away from home.
Harmony Hub works with over 270,000 entertainment and smart home devices so you can enjoy single-touch control with your favorite brands, right out of the box. From your TV, cable and gaming console, to your AV receiver and Roku® media player -- all the way to your smart lights, locks, thermostats, and even your Alexa -- Harmony Hub proudly works with just about everything.
Lower the blinds, dim the lights, fire-up the TV for movie night -- all with a tap of the finger. With Harmony Activities you can enjoy single-touch automation to trigger limitless experiences. Harmony automatically suggests everyday Activities or you can have fun creating as many as you can dream up. Time for bed? Tap "Good Night" to lock the door and turn out the lights, then fall into a deep and tranquil sleep.
HARMONY HUB AT-A-GLANCE
ONE-TOUCH ACTIONS
Use the app to launch Activities or switch to one of 50 channel favorites with a single touch.
CLOSED CABINET CONTROL
Control your devices behind closed cabinets and doors with IR, Wi-Fi and Bluetooth® wireless.
CUSTOM ACTIVITIES
Create unlimited one-touch or time-triggered activities that group devices into custom experiences.
UNIVERSAL CONTROL
Combine up to 8 remotes and countless apps into one easy-to-use smartphone app.
OUT OF HOME REMOTE
Set recordings, turn on the lights, or activate any of your devices while you're not home.
EASY SET-UP
Download the Harmony App. Auto-scan for devices. Create custom Activities and Favorites.
What's in the box?
  • Harmony Hub
  • IR mini-blaster
  • USB cable
  • AC adapter
  • User documentation
Product Description Logitech HARMONY HUB - central controller
Product Type Central controller
Functions Turn electronics on/off, light control
Internet of Things (IoT) Platform Harmony
Package Content Remote control
Connectivity Wireless - Bluetooth, 802.11b/g/n
Supported Host Device OS iOS, Android
Dimensions (WxDxH) 10.48 cm x 2.54 cm x 12.8 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
£89.98
