We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Your remote, evolved
Simple to use design
Both the screen and the backlit keys light up when the remote senses motion. A gentle vibration tells you a command is received.
Eyes-free gesture control
Keep your eyes on your entertainment. Simple swipes and taps change channels, adjust volume, or control playback.
Make it your own
Personalize the 2.4inch color touchscreen with frequently-used commands, Activities, and up to 50 channel Favorites.
One-touch Activities
Touch an Activity like "Watch a Movie" or "Watch TV" and the right devices switch on with just the right settings.
Power at the ready
The charging station keeps Harmony Ultimate One fully charged and easy to find. No more hunting in the sofa cushions.
Harmony compatibility
Harmony Ultimate One controls up to 15 IR devices and is compatible with over 270,000 models from more than 6,000 brands.
Easy online setup
Harmony Ultimate One set-up takes only a few minutes at myharmony.com. Harmony One users can even import their settings.
What's in the box?
Product Description | Logitech Harmony Ultimate One universal remote control | Device Type | Universal remote control | Connectivity Technology | Infrared | Supported Device Qty | 15 | Input Device | Keypad, touch screen | Battery | Rechargeable | Manufacturer Warranty | 2-year warranty |
General | |
Features | Rechargeable |
System Requirements | |
Operating System | MS Windows XP, MS Windows 7, Apple Mac OS X 10.6.x or later, MS Windows Vista, Windows 8 |
Miscellaneous | |
Included Accessories | AC power adaptor, USB cable, charging stand |
Power | |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
