Logitech Keyboard K120 - USB
£12.82
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • With low-profile keys, a standard layout and a sleek yet sturdy design, this USB keyboard gives you a better typing experience that's built to last.
  • Comfortable, quiet typing
  • Spill-resistant design 1
  • Thin profile
  • Durable keys
  • Sturdy, adjustable tilt legs
  • Recommended Use: Leisure, Office
  • Type: Keyboard
  • Wired / Wireless: Wired
  • Colour: Black
  • Compatibility: PC
Product codes
Bundle deals (1)
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £16.31
Save £1.50
Your hands will enjoy the low-profile, whisper-quiet keys and standard layout with full-size F-keys and number pad. The slim keyboard isn't just sleek-it's tough with a spill-resistant design, sturdy tilt legs and durable keys. You simply plug it into a USB port on your desktop, laptop or netbook computer and start using it right away.
You'll enjoy a comfortable and quiet typing experience thanks to the low-profile keys that barely make a sound and standard layout with full-size F-keys and number pad.
Liquid drains out of the keyboard, so you don't have to worry about ruining your investment with accidental spills
Thin profile
The keyboard has a thin profile that adds a sleek look to your desk while keeping your hands in a more comfortable, neutral position.
Durable keys
The keys can last up to 10 million keystrokes so you can keep typing long after many keyboards have called it quits
Plug-and-play USB connection
Setup is simple--you just plug it into a USB port on your desktop, laptop or netbook computer and start using it right out of the box.
Easy-to-read keys
The bold, bright white characters make the keys easier to read--perfect for those with less-than-perfect vision. They're less likely to wear off, too.
Curved space bar
It keeps your hands in a more natural position so you can type in greater comfort.
Logitech reliability
You get the high quality and reliability that's made Logitech the global leader for keyboards and mice at a price you can afford--plus a 3-year warranty.
Product Description Logitech K120 - keyboard - UK
Device Type Keyboard
Interface USB
Connectivity Technology Wired
Localization and Layout UK
Features Spillproof
Dimensions (WxDxH) 45 cm x 15.5 cm x 2.4 cm
Weight 0.55 kg
Microsoft Certification Compatible with Windows 7
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Logitech Keyboard K120...
£12.82
