Logitech Logi Base Charger for Ipad Pro
£81.74
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • SLEEK, MODERN DESIGN
  • EASIEST WAY TO CHARGE YOUR IPAD PRO
  • PERFECT VIEWING ANGLE
  • BUILT FOR STABILITY
  • USEFUL IN EVERY ROOM WITH SIRI
  • HEY, SIRI
  • DESIGNED IN COLLABORATION WITH APPLE
  • SCRATCH-FREE DOCKING
  • MFi CERTIFIED
  • 1-YEAR WARRANTY
  • Stock Status: In Stock
Product codes
Logi BASE uses Apple Smart Connector technology to bring you a new charging experience. BASE gives your iPad Pro the perfect spot to recharge in any room of the house - and while you're using it too. It has magnets in the charging cradle to perfectly align iPad Pro with the Smart Connector. The Smart Connector has a minimal profile that makes it effortless to place your iPad Pro in the charging position. Just place your iPad Pro on BASE and it begins to charge.
Logi BASE gives you an ideal viewing angle to use your iPad Pro on a table or countertop anywhere in the house. Set your iPad Pro on BASE in the kitchen to follow your favorite recipes. Say "Hey, Siri " and ask for hands free help to set a timer, convert tablespoons into cups or cups into ounces, or make a FaceTime call to your mom when you get completely lost in a recipe. Set your BASE in the bedroom and make your morning routine a breeze. With a "Hey, Siri" you can check the weather, your schedule, and crank your favorite morning tunes, all hands free. BASE also works great on your desk, allowing you to use your iPad Pro as an extension of your laptop or desktop screen.
Product Description Logitech BASE charging stand
Product Type Charging stand
Dimensions (WxDxH) 17.8 cm x 11.4 cm x 8.2 cm
Weight 357 g
Output Connector Type Smart Connector
Designed For Apple 12.9-inch iPad Pro (1st generation, 2nd generation); 9.7-inch iPad Pro
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Logitech Logi Base Cha...
£81.74
