Logitech M105 Mouse White
£12.24
Delivery:
Standard: 1-3 working days
Key features
  • It's the cool, colorful corded mouse at a comfortable price.
  • Simple to set up and use
  • High-definition optical tracking
  • Full-size comfort, ambidextrous design
  • Built by Logitech
  • Plug and play
  • Type: Mouse
  • Wired / Wireless: Wired
  • Colour: White
  • Compatibility: Mac, PC, Unix
  • Stock Status: In Stock
Product codes
Bundle deals (1)
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £15.73
Save £1.50
Just plug the mouse into a USB port and it's ready to use. No software or batteries required.
You'll enjoy smooth cursor control, precise tracking and easy text selection.
Your hand will be more comfortable than with your touchpad.
Product Description Logitech M105 - mouse - USB - white
Device Type Mouse
Connectivity Technology Wired - USB
Colour White
Movement Detection Technology Optical
Features Scrolling wheel
Cables Included 1 x USB cable - integrated
OS Required Linux Kernel 2.6 or later, Microsoft Windows Vista / XP / 7, Apple MacOS X 10.5 or later
Microsoft Certification Compatible with Windows 7
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
£12.24
