We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Hush... M590 Multi-Device Silent lets you get through your tasks with noiseless efficiency. Using Logitech Flow, it has the almost magical capacity to navigate seamlessly on two computers and copy-paste from one to the other. Its click noise reduction ensures, you won't be disturbing those around you.
Product Description | Logitech M590 Silent - mouse - Bluetooth, 2.4 GHz - graphite tonal | Device Type | Mouse | Connectivity Technology | Wireless - Bluetooth, 2.4 GHz | Colour | Graphite tonal | Orientation | Right-handed | Dimensions (WxDxH) | 6.4 cm x 10.3 cm x 4 cm | Weight | 101 g | Wireless Receiver | USB wireless receiver | Movement Detection Technology | Optical | Buttons Qty | 7 | Movement Resolution | 1000 dpi | Features | Battery indicator, on/off power switch, Logitech Unifying receiver, Logitech Advanced Optical Tracking, precision scroll wheel | Battery | AA type | OS Required | Google Chrome OS, Android 5.0 or later, Apple MacOS X 10.10 or later, Windows 8 / 10 | Manufacturer Warranty | 2-year warranty |
General | |
Width | 6.4 cm |
Depth | 10.3 cm |
Height | 4 cm |
Weight | 101 g |
Input Device | |
Connectivity Technology | Wireless |
Interface | Bluetooth, 2.4 GHz |
Max Operating Distance | Up to 10 m |
Buttons Qty | 7 |
Expansion / Connectivity | |
Interfaces | 1 x USB - 4 pin USB Type A |
Battery | |
Type | AA type |
Run Time (Up To) | 24 months |
Software / System Requirements | |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
