Logitech M90 Wired Scroll Mouse
£6.66
43 in stock
Delivery:
Standard: 1-3 working days
Key features
  • With plug-and-play simplicity and high-definition optical tracking, you get a great value and reliable, comfortable control of your computer.
  • Simple to set up and use
  • Full-size comfort, ambidextrous design
  • High-definition optical tracking
  • Built by Logitech
  • Just the basics
  • No false moves
  • From the mouse experts
  • Recommended Use: Leisure, Office
  • Type: Mouse
  • Wired / Wireless: Wired
  • Colour: Dark grey
  • Compatibility: Mac, PC
Product codes
Setup is fast and easy--just plug the cable into a USB port. There's no software to install. And since it's corded, you can just plug the cable into a USB port and use it right away
Designed to keep either hand happy. So you'll feel comfortable, even after hours of use.
You'll enjoy responsive, smooth cursor control, precise tracking and easy text selection thanks to high-definition optical tracking (1000 dpi).
Built by Logitech
This mouse comes with the quality and design we've built into more than a billion mice, more than any other manufacturer.
Product Description Logitech M90 - mouse - USB
Device Type Mouse
Connectivity Technology Wired - USB
Orientation Right and left-handed
Localisation Western Europe
Movement Detection Technology Optical
Movement Resolution 1000 dpi
Features Scrolling wheel
OS Required Apple MacOS X 10.4 or later, Linux Kernel 2.6.x or later, Microsoft Windows Vista / XP / 7
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Logitech M90 Wired Scr...
£6.66
