We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Meet MK540, a wireless keyboard and mouse combo built for precision, comfort, and reliability. The full-size keyboard features a familiar key shape, size, and feeling - optimized for precision and noise reduction. The palm rest and adjustable tilt legs keep you comfortable for long stretches and the contoured mouse is designed to fit perfectly into either palm.
Product Description | Logitech MK540 Advanced - keyboard and mouse set - QWERTY - US International | Device Type | Keyboard and mouse set | Interface | 2.4 GHz | Wireless Receiver | Logitech Unifying receiver | Input Device | Keyboard | Connectivity Technology | Wireless | Localization and Layout | QWERTY US International | Numeric Keypad | Yes | Pointing Device | Mouse - wireless - optical - right and left-handed | Buttons Qty | 3 | Manufacturer Warranty | 2-year warranty |
General | |
Max Operating Distance | Up to 10 m |
Dimensions (WxDxH) / Weight | Keyboard: 45.73 cm x 19.35 cm x 2.4 cm / 805 g , Mouse: 6.18 cm x 11.15 cm x 3.92 cm / 73.5 g |
Input Device | |
Type | Keyboard - wireless |
Palm Rest | Yes |
Features | Numeric keypad |
Pointing Device | |
Type | Mouse - wireless |
Buttons Qty | 3 |
Movement Detection Technology | Optical |
Orientation | Right and left-handed |
Supported Battery Type | AA x 1 |
Miscellaneous | |
Compliant Standards | Plug and Play |
Software & System Requirements | |
OS Required | Google Chrome OS, Microsoft Windows 7 / 8 / 10 |
Battery | |
Type | AA type |
Installed Qty | 2 |
Required Qty | 2 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
