We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
MX Master 3 is instant precision and infinite potential. It's an advanced Master series mouse - designed for creatives and engineered for coders. If you can think it, you can master it.
Product Description | Logitech MX Master 3 - mouse - Bluetooth, 2.4 GHz - graphite | Device Type | Mouse | Connectivity Technology | Wireless - Bluetooth, 2.4 GHz | Colour | Graphite | Dimensions (WxDxH) | 8.43 cm x 12.49 cm x 5.1 cm | Weight | 141 g | Wireless Receiver | USB wireless receiver | Movement Detection Technology | Laser | Buttons Qty | 7 | Movement Resolution | 4000 dpi | Performance | Realtime sensitivity switching 200 - 4000 dpi | Features | Logitech Darkfield Laser Tracking, side wheel, gesture function, MagSpeed wheel | OS Required | Linux, Microsoft Windows 7 / 8 / 10, Apple macOS 10.13 or later | Manufacturer Warranty | 2-year warranty |
General | |
Width | 8.43 cm |
Depth | 12.49 cm |
Height | 5.1 cm |
Weight | 141 g |
Colour | Graphite |
Input Device | |
Connectivity Technology | Wireless |
Interface | Bluetooth, 2.4 GHz |
Max Operating Distance | Up to 10 m |
Buttons Qty | 7 |
Expansion / Connectivity | |
Interfaces | 1 x USB - 4 pin USB Type A |
Miscellaneous | |
Included Accessories | USB-C charging cable |
Battery | |
Technology | Lithium polymer |
Capacity | 500 mAh |
Run Time (Up To) | 70 days |
Software / System Requirements | |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
