Meet MX Master 3S – an iconic mouse remastered. Feel every moment of your workflow with even more precision, tactility, and performance, thanks to Quiet Clicks and an 8,000 DPI track-on-glass sensor.
Product Description | Logitech Master Series MX Master 3S - mouse - Bluetooth, 2.4 GHz - pale grey | Device Type | Mouse - ergonomic | Connectivity Technology | Wireless - Bluetooth, 2.4 GHz | Colour | Pale grey | Dimensions (WxDxH) | 8.43 cm x 12.49 cm x 5.1 cm | Weight | 141 g | Wireless Receiver | Logitech Logi Bolt USB receiver | Movement Detection Technology | Optical | Buttons Qty | 7 | Movement Resolution | 8000 dpi | Performance | Realtime sensitivity switching 200 - 8000 dpi | Features | Logitech Darkfield Laser Tracking, Easy-Switch technology, gesture function, rechargeable battery, thumb rest, MagSpeed wheel, customisable DPI, thumb wheel, Quiet Clicks technology | OS Required | Linux, Google Chrome OS, Android 8.0 (Oreo) or later, Apple macOS 10.15 or later, Apple iPadOS 14 or later, Windows 10 / 11 or later | Product Recycled Content | 22 % - made of recycled post-consumer plastic | Manufacturer Warranty | 2-year warranty |
General | |
Device Type | Mouse |
Ergonomic Design | Yes |
Width | 8.43 cm |
Depth | 12.49 cm |
Height | 5.1 cm |
Weight | 141 g |
Product Material | Plastic, CNC machined steel |
Input Device | |
Connectivity Technology | Wireless |
Interface | Bluetooth, 2.4 GHz |
Max Operating Distance | Up to 10 m |
Buttons Qty | 7 |
Expansion / Connectivity | |
Interfaces | 1 x USB - 4 pin USB Type A |
Miscellaneous | |
Included Accessories | USB-C charging cable |
Battery | |
Technology | Lithium polymer |
Capacity | 500 mAh |
Run Time (Up To) | 70 days |
Software / System Requirements | |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
