Ultra-precise and stable switches offer deep and reassuring key travel – in a low-profile form factor. Your fingers glide effortlessly across the matte surface of the keys – and dual color keycaps make it easy to orient your fingers and stay in your flow.
Product Description | Logitech Master Series MX Mechanical - keyboard - QWERTY - UK - graphite | Device Type | Keyboard | Backlit | Yes | Interface | Bluetooth LE | Wireless Receiver | Logitech Logi Bolt USB receiver | Connectivity Technology | Wireless | Localization and Layout | QWERTY UK | Hot Keys Function | Multimedia, mute, backlight control, Easy-Switch, on/off switch | Numeric Keypad | Yes | Key Switch Type | Tactile Quiet | Colour | Graphite | Dimensions (WxDxH) | 43.385 cm x 13.155 cm x 2.61 cm | Weight | 828 g | Manufacturer Warranty | 2-year warranty |
General | |
Backlit | Yes |
Max Operating Distance | Up to 10 m |
Input Device | |
Type | Wireless |
Keyboard Technology | Mechanical |
Adjustable Height | Yes |
Features | Numeric keypad |
Width | 43.385 cm |
Depth | 13.155 cm |
Height | 2.61 cm |
Weight | 828 g |
Miscellaneous | |
Colour | Graphite |
Included Accessories | USB-C charging cable |
Software & System Requirements | |
OS Required | Linux, Android, Google Chrome OS, Apple macOS 10.15 or later, Apple iOS 14 or later, Apple iPadOS 14 or later, Windows 10 / 11 or later |
Battery | |
Type | Rechargeable |
Technology | Lithium polymer |
Run Time (Up To) | 10 months |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
