Logitech PC 960 Stereo Headset USB For Business
£24.99
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Express: Delivered tomorrow
Express Delivery:
  • 00 h
  • 00 m
  • 00 s
Key features
  • HEAR EVERY WORD
  • CALLERS ONLY HEAR YOU
  • EASY TO USE, JUST PLUG AND PLAY
  • COMFORTABLE ALL DAY WEAR
  • Recommended Use: Computer
  • Connectivity: Wired
  • Earcover : Binaural
  • Stock Status: In Stock
Product codes
Documents
Bundle deals (1)
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £28.48
Save £1.50
The Logitech® PC Headset 960 USB features a comfortable and lightweight headband with volume controls and adjustable boom microphone . The noise-canceling microphone filters unwanted background noise. Ships in a business pack.
Stylish, adjustable over-the-head design for a comfortable fit that won't slip off. Ultra-soft earpad, flexible and lightweight design ensures all-day comfort. USB cable for simple, plug-and-play connectivity. Adjustable boom microphone for precise positioning; the microphone rotates out of the way when not in use. In-line volume or mute controls for easy and precise control. Microphone mute indicator light tells you when mute is enabled. Advanced digital USB delivers superior stereo sound quality. Noise-canceling microphone filters background noise for clearer conversations. White-box business packaging is easy to ship, store and recycle. 3-Year warranty.
The Logitech® PC Headset 960 USB features a comfortable and lightweight headband for all day wear, with in-line controls for volume and mute adjustment. The boom microphone can be adjusted to the optimal position for clearer conversations. The noise-cancelling microphone filters backgound noise, and rotates out of the way when not in use. Ships in a business pack ideal for system builders, integrators and value-added resellers
Product Description Logitech PC Headset 960 USB - headset
Product Type Headset - wired
Recommended Use Computer
Headphones Form Factor On-ear
Connectivity Technology Wired
Headphones Technology Dynamic
Sound Output Mode Stereo
Audio Specifications Frequency Response 20 - 20000 Hz
Microphone Boom
Controls Volume, microphone on/mute
Resources
The following resources are available for the Logitech PC 960 Stereo Headset USB For Business
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Logitech PC 960 Stereo...
£24.99
