Logitech Pop Home Add-on Switch - Coral
£36.26
Colours:
Delivery:
Key features
  • POP THE LIGHTS
  • POP THE MUSIC
  • POP EVERYTHING, TOGETHER
  • POP NEARLY ANYWHERE
  • Type: Switch
  • Compatible With: Apple Homekit, IFTTT
Product codes
POP Home Switch lets everyone in the home control smart lighting, music, and more with the push of a button. Program each switch with up to three custom commands to add creativity and convenience throughout your smart home. Whether it's movies, reading, or a party, POP makes it easy to match lighting with lifestyle. Configure your lights for brightness, warmth, and color and enjoy simple push-button control. Program POP to play your favorite music at just the right volume. Add lighting to the mix to create Recipes that instantly set the mood, from early morning waking up, to late night rocking out. Create Recipe combinations to trigger multiple smart devices at once, like setting smart locks and night-lights before going to bed.
Because each switch is wireless and battery-powered, you can use POP just about anywhere. Mount one by the front door, keep one on your nightstand, or carry one from room to room. Add simple smart home control wherever you like. POP Home Switch combines with the POP bridge and POP app, to deliver powerful functionality that is effortless to use. Use the POP app to scan for devices. Drag-and-drop to add to a POP home switch, or create a multi-device Recipe. Press once, press twice or press-and-hold to trigger different preset commands. Each switch's replaceable battery lasts for years with typical household use.
Product Description Logitech POP Add-on Home Switch - switch
Product Type Switch
Power Source Battery
Connectivity Wireless - Bluetooth, Wi-Fi
Supported Host Device OS iOS, Android
Colour Coral
Manufacturer Warranty 1-year warranty
Dimensions (WxDxH) 6 cm x 0.9 cm x 6 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Logitech Pop Home Add-...
£36.26
