Logitech R400 Wireless Presenter - Remote Control
£22.72
16 in stock
Delivery:
Standard: 1-3 working days
Key features
  • A wireless presenter-with intuitive controls and a red laser pointer-that helps you make your point.
  • Intuitive slideshow controls
  • Red laser pointer
  • Up to 15-meter range
  • Battery indicator
  • Plug-and-play wireless receiver
  • Confidence boost
  • Move freely
  • Ready to go
  • Recommended Use: Office
  • Type: Wireless Presenter
  • Wired / Wireless: Wireless
  • Colour: Black
  • Compatibility: PC
Product codes
Buttons are easy to find by touch. And the smooth contours feel great in your hand. You'll be in control from the first slide to the last.
It'll be easy for your audience to see exactly what you're pointing to.
The 2.4 GHz wireless allows you to enjoy the freedom to move around the room and mingle with your audience for greater impact.
Lets you know how much power is available with just a glance.
There's no software to install. Just plug the receiver into a USB port to begin. And when the show is over, you can store the receiver in the presenter.
Product Description Logitech Wireless Presenter R400 presentation remote control
Device Type Presentation remote control
Dimensions (WxDxH) 11.55 cm x 3.78 cm x 2.74 cm
Weight 57 g
Connectivity Technology Radio
Supported Devices Personal computer
Max Operating Distance 15 m
Battery Standard - AAA type Alkaline
Microsoft Certification Compatible with Windows 7
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Logitech R400 Wireless...
£22.72
