We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Slim Folio takes mobile computing to a higher level. Now you can enjoy laptop-like typing anywhere you take your tablet. Its slim, light design makes it a joy to use and carry around, all the while keeping your device safe from bumps, scratches and spills. No matter where you need to get your work done - a café table, a desk or even your lap - Slim Folio locks your tablet at an optimal angle for typing and holds firm on any surface.
Product Description | Logitech Slim Folio - keyboard and folio case - QWERTY - UK - graphite | Device Type | Keyboard and folio case | Interface | Bluetooth | Input Device | Keyboard | Localization and Layout | QWERTY UK | Hot Keys Function | Multimedia, iPad functions | Protection | Scratch-resistant, spill-resistant | Colour | Graphite | Case Material | Plastic, fabric | Dimensions (WxDxH) | 25.7 cm x 2 cm x 18.5 cm | Weight | 485 g | Manufacturer Warranty | 2-year warranty | Designed For | Apple 10.5-inch iPad Air (3rd generation) |
General | |
Input Device | |
Type | Keyboard |
Keyboard Technology | Scissors |
Width | 25.7 cm |
Depth | 2 cm |
Height | 18.5 cm |
Weight | 485 g |
Carrying Case | |
Features | Pen holder, sleep/wake function, water repellent |
Miscellaneous | |
Colour | Graphite |
Battery | |
Installed Qty | 2 |
Required Qty | 2 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Compatibility Information | |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
