Slim Folio takes mobile computing to a higher level. Now you can enjoy laptop-like typing anywhere you take your tablet. Its slim, light design makes it a joy to use and carry around, all the while keeping your device safe from bumps, scratches and spills. No matter where you need to get your work done - a café table, a desk or even your lap - Slim Folio locks your tablet at an optimal angle for typing and holds firm on any surface.
Product Description | Logitech Slim Folio - keyboard and folio case - QWERTY - UK - graphite | Device Type | Keyboard and folio case | Interface | Bluetooth | Input Device | Keyboard | Localization and Layout | QWERTY UK | Hot Keys Function | Search, mute, play/pause, previous track, next track, home screen, Siri, volume -, volume +, language key | Protection | Scratch-resistant, spill-resistant | Colour | Graphite | Case Material | Plastic, fabric | Dimensions (WxDxH) | 24.8 cm x 2 cm x 18.2 cm | Weight | 445 g | Manufacturer Warranty | 2-year warranty | Designed For | Apple 10.2-inch iPad (7th generation, 8th generation) |
General | |
Input Device | |
Type | Keyboard |
Keyboard Technology | Scissors |
Width | 24.8 cm |
Depth | 2 cm |
Height | 18.2 cm |
Weight | 445 g |
Carrying Case | |
Features | Pen holder, sleep/wake function, water repellent |
Miscellaneous | |
Colour | Graphite |
Battery | |
Installed Qty | 2 |
Required Qty | 2 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Compatibility Information | |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
