Essential stereo headset works on all operating systems and platforms via the standard 3.5mm audio jack connection. Just plug your headset into the 3.5mm port on your computer, tablet or smartphone and it's ready to go. In-line controls let you control volume or mute calls without disruption. Convenient noise-cancelling microphone reduces background noise.
Product Description | Logitech Stereo H151 - headset | Product Type | Headset - wired | Recommended Use | Computer | Headphones Form Factor | On-ear | Connectivity Technology | Wired | Headphones Technology | Dynamic | Sound Output Mode | Stereo | Audio Specifications | Sensitivity 122 dB | Impedance | 22 Ohm | Microphone | Boom | Controls | Volume, microphone on/mute | Manufacturer Warranty | 2-year warranty |
General | |
Width | 15 cm |
Depth | 20 cm |
Height | 6 cm |
Weight | 80 g |
Audio Output | |
Sensitivity | 122 dB |
In-Cord Volume Control | Yes |
Microphone | |
Type | Boom |
Sensitivity | -44 dBV/Pascal |
Frequency Response | 100 - 6500 Hz |
Remote Control | |
Connections | |
Connector Type | Headset (mini-phone stereo 3.5 mm 4-pole) |
Miscellaneous | |
Cable Details | Headset cable - 1.8 m |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Dimensions & Weight (Shipping) | |
Shipping Width | 6.99 cm |
Shipping Depth | 19.1 cm |
Shipping Height | 23.97 cm |
Shipping Weight | 263 g |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
