With more than 3x the reach of ordinary USB 3.x cables, Logitech Strong USB lets you separate self-powered USB 2.0 and 3.x peripherals and a host PC by up to 10 meters. The aramid-reinforced active optical cable is plenum-rated and Eca certified for safe operation and reliable performance to 10Gbps. By eliminating the need for USB extenders, Logitech Strong USB eliminates points of failure while reducing cost and complexity. Unlike typical USB cables that can break during or after installation, Logitech Strong USB is plenum-rated and Eca certified to pull through walls, above ceilings, and within standard ¾" conduit.
Product Description | Logitech Strong - USB-C cable - USB Type A to 24 pin USB-C - 10 m | Type | USB-C cable | Features | Plenum, Active Optical Cable (AOC), aramid-reinforced sheath, 3/4" conduit friendly | Length | 10 m | Connector | 9 pin USB Type A - male | Connector (Second End) | 24 pin USB-C - male | Compliant Standards | USB 2.0 / USB 3.0 / USB 3.1 | Manufacturer Warranty | 2-year warranty |
General | |
Length | 10 m |
Connectivity | |
Miscellaneous | |
Compliant Standards | USB 2.0 / USB 3.0 / USB 3.1, IEC 60332-1-2 |
Dimensions & Weight (Shipping) | |
Service & Support | 2-year warranty |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
