Logitech Strong USB cable USB Type A (M) to USB-C (M) USB 3....
Logitech Strong USB cable USB Type A (M) to USB-C (M)  USB 3.1 10m
£296.60
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • KEY FEATURES
  • EXTENDED REACH
  • RELIABLE STRENGTH
  • FAST AND COMPATIBLE
  • Length: 10m
Product codes
With more than 3x the reach of ordinary USB 3.x cables, Logitech Strong USB lets you separate self-powered USB 2.0 and 3.x peripherals and a host PC by up to 10 meters. The aramid-reinforced active optical cable is plenum-rated and Eca certified for safe operation and reliable performance to 10Gbps. By eliminating the need for USB extenders, Logitech Strong USB eliminates points of failure while reducing cost and complexity. Unlike typical USB cables that can break during or after installation, Logitech Strong USB is plenum-rated and Eca certified to pull through walls, above ceilings, and within standard ¾" conduit.
Product Description Logitech Strong - USB-C cable - USB Type A to 24 pin USB-C - 10 m
Type USB-C cable
Features Plenum, Active Optical Cable (AOC), aramid-reinforced sheath, 3/4" conduit friendly
Length 10 m
Connector 9 pin USB Type A - male
Connector (Second End) 24 pin USB-C - male
Compliant Standards USB 2.0 / USB 3.0 / USB 3.1
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£296.60
