Logitech Trackman Marble Mouse - Wired USB
£45.48
Delivery:
Key features
  • You'll enjoy all-day comfort with this ambidextrous trackball with convenient button controls.
  • Ambidextrous trackball design
  • Stable base
  • Convenient button controls
  • Fingertip-based control
  • Marble optical technology
  • All-day comfort
  • Back and forth
  • Marble marvel
  • Recommended Use: Leisure
  • Type: Trackball
  • Wired / Wireless: Wired
  • Colour: Red, Silver
  • Compatibility: Mac, PC
Product codes
The Logitech TrackMan Marble gives you superior comfort - for either hand. Ambidextrous design provides long-lasting comfort for right- and left-handed people. Convenient button controls let you easily move forward and backward when you're surfing the Web. Click the large buttons together and use the ball for auto-scrolling. Fingertip-based control enables fast, accurate cursor movements. Patented Marble optical technology ensures smooth tracking.
Left handed? Right handed? When you're working on your computer day and night, and you want more flexibility, the Logitech Trackman Marble will help increase your comfort level.
A trackball design with a long, broad palm area and gentle curves keeps your hand comfortable and supported all day--whether you use your right or left hand.
Stable base
Your hand stays comfortable all day long with this stay-put design. Plus, it saves you space.
Buttons let you easily move forward and backward when you're surfing the Web.
You'll enjoy fast, accurate cursor movement with just a move of your finger.
MarbleĀ® optical technology
Our patented technology gives you smooth tracking on almost any surface so you can be productive wherever you work.
Product Description Logitech Trackman Marble - trackball - USB
Device Type Trackball
Connectivity Technology Wired - USB
Orientation Right and left-handed
Movement Detection Technology Optical
Buttons Qty 4
Features Logitech Marble optical technology
Cables Included 1 x USB cable - integrated
OS Required Apple MacOS X 10.3.9 or later, Microsoft Windows Vista / XP
Microsoft Certification Works with Windows Vista
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Logitech Trackman Marb...
£45.48
