A versatile headset lets you get comfortable with digital sound. You'll be comfortable with this headset thanks to the plush ear pads and padded headband that adjusts to you. You've got it easy - this plug-and-play USB headset gives you quick access to volume and mute controls.
Product Description | Logitech USB Headset H390 - headset | Product Type | Headset - wired | Recommended Use | Computer | Headphones Form Factor | Full size | Connectivity Technology | Wired | Sound Output Mode | Stereo | Audio Specifications | Frequency Response 20 - 20000 Hz - Sensitivity -62 dBV/uBar | Microphone | Boom | Microphone Operation Mode | Mono | Controls | Mute, volume | Manufacturer Warranty | 2-year warranty |
General | |
Audio Output | |
Frequency Response | 20 - 20000 Hz |
Sensitivity | -62 dBV/uBar |
In-Cord Volume Control | Yes |
Microphone | |
Type | Boom |
Sensitivity | -42 dBV/Pascal |
Frequency Response | 100 - 10000 Hz |
Remote Control | |
Connections | |
Connector Type | USB |
Miscellaneous | |
Cable Details | Headset cable - 2.4 m |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
