Logitech USB HEADSET H390
£33.94
Delivery:
Key features
  • A versatile USB headset with an adjustable, padded headband that lets you get comfortable with pure digital sound.
  • Comfortable design
  • Noise-canceling microphone
  • Rotating microphone
  • In-line audio controls
  • Pure digital USB
  • Feeling good
  • Loud and clear
  • Easy listening
  • Recommended Use: Computer
  • Connectivity: Wired
  • Earcover : Binaural
Product codes
A versatile headset lets you get comfortable with digital sound. You'll be comfortable with this headset thanks to the plush ear pads and padded headband that adjusts to you. You've got it easy - this plug-and-play USB headset gives you quick access to volume and mute controls.
Product Description Logitech USB Headset H390 - headset
Product Type Headset - wired
Recommended Use Computer
Headphones Form Factor Full size
Connectivity Technology Wired
Sound Output Mode Stereo
Audio Specifications Frequency Response 20 - 20000 Hz - Sensitivity -62 dBV/uBar
Microphone Boom
Microphone Operation Mode Mono
Controls Mute, volume
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
£33.94
