Logitech USB Headset H540
£47.47
19 in stock
Delivery:
Standard: 1-3 working days
Key features
  • HIGH-DEFINITION SOUND QUALITY
  • NOISE CANCELING MIC
  • ON-EAR CONTROLS
  • PADDED COMFORT
  • USB CONNECTION
  • Recommended Use: Computer
  • Connectivity: Wired
  • Earcover : Binaural
  • Stock Status: In Stock
Product codes
It is a high-quality, high-performance headset that brings your PC calls and music to life. Enjoy volume and bass level control, as well as the ability to instantly mute the mic - all at your fingertips and the soft leatherette padded headband and earcups allow you to talk or listen in comfort, for hours on end.
Soft leatherette padding is easy on your ears - especially when you're listening to music or chatting for hours. Worried about the fit? Don't be. The padding on the headband ensures a fit that molds comfortably to the contours of your head.
Product Description Logitech USB Headset H540 - headset
Product Type Headset - wired
Recommended Use Computer
Headphones Form Factor On-ear
Connectivity Technology Wired
Sound Output Mode Stereo
Audio Specifications Frequency Response 20 - 20000 Hz
Microphone Boom
Microphone Operation Mode Mono
Controls Volume
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
£47.47
