It is a high-quality, high-performance headset that brings your PC calls and music to life. Enjoy volume and bass level control, as well as the ability to instantly mute the mic - all at your fingertips and the soft leatherette padded headband and earcups allow you to talk or listen in comfort, for hours on end.
Soft leatherette padding is easy on your ears - especially when you're listening to music or chatting for hours. Worried about the fit? Don't be. The padding on the headband ensures a fit that molds comfortably to the contours of your head.
Product Description | Logitech USB Headset H540 - headset | Product Type | Headset - wired | Recommended Use | Computer | Headphones Form Factor | On-ear | Connectivity Technology | Wired | Sound Output Mode | Stereo | Audio Specifications | Frequency Response 20 - 20000 Hz | Microphone | Boom | Microphone Operation Mode | Mono | Controls | Volume | Manufacturer Warranty | 2-year warranty |
General | |
Headphones | |
Frequency Response | 20 - 20000 Hz |
Microphone | |
Type | Boom |
Sensitivity | -40 dBV/Pascal |
Frequency Response | 100 - 10000 Hz |
Remote Control | |
Controls | Volume |
Connections | |
Connector Type | USB (4 PIN USB Type A) |
Miscellaneous | |
Cables Included | USB cable - 1.8 m |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
