Cut loose from your PC with this lightweight, portable headset. The laser-tuned drivers and 10-meter range make it easy to listen and chat whether you're at your desk or on the couch.
Product Description | Logitech Wireless Headset H600 - headset | Product Type | Headset - 2.4 GHz - wireless | Recommended Use | Computer | Headphones Form Factor | On-ear | Connectivity Technology | Wireless | Wireless Technology | 2.4 GHz radio frequency | Radio Frequency Range | 2.4GHz | Sound Output Mode | Stereo | Microphone | Boom | Microsoft Certification | Compatible with Windows 7 | Manufacturer Warranty | 2-year warranty |
General | |
Max Operating Distance | 10 m |
Headphones | |
Microphone | |
Type | Boom |
Wireless Link | |
Transmission Range | 10 m |
Connections | |
Connector Type | USB (4 PIN USB Type A) |
Miscellaneous | |
Cables Included | USB charge cable |
Included Accessories | Wireless adapter |
Compatible with Windows 7 | "Compatible with Windows 7" software and devices carry Microsoft’s assurance that these products have passed tests for compatibility and reliability with 32-bit and 64-bit Windows 7. |
Power | |
Battery | Headphone battery |
Run Time (Up To) | 6 hour(s) |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
