The feel-good, reliable mouse with more precise navigation and soft rubber grips.
From surfing the web to updating your Facebook - you'll be mousing on more surfaces thanks to Logitech optical. No delays, dropouts or hassles. The plug-and-forget nano-receiver keeps you connected with reliable wireless.
Logitech® Advanced Optical Tracking
Enjoy precise clicking and pointing--on surfaces other optical mice can't handle--while navigating your favorite websites thanks to Logitech Advanced Optical Tracking.
Logitech Advanced 2.4 GHz wireless connectivity
You get the reliability of a cord with wireless convenience and freedom--fast data transmission and virtually no delays or dropouts.
1-year battery life
You can go for a year without battery hassles. An On/Off switch and smart sleep mode extend battery life, while an indicator light eliminates surprises
Plug-and-forget nano-receiver
So small and unobtrusive, you can plug it into a USB port and forget about it. Plus, you can say good-bye to worries about broken or lost receivers.
Compact comfort
You'll enjoy more comfort and ease thanks to this compact mouse's hand-friendly, contoured design with soft rubber grips and a smooth scroll wheel.
Logitech reliability
You get the high quality and reliability that have made Logitech the global leader for mice--plus a three-year limited hardware warranty.
Perfect for laptops and netbooks
Your mouse works with Windows®, Mac® and Linux®. No matter what type of computer you own today--or buy tomorrow--you can depend on your mouse to work like you expect.
