Logitech Wireless Mouse M235 - Optical - 2.4 GHz USB wireless...
Logitech Wireless Mouse M235 - Optical - 2.4 GHz USB wireless receiver - Silver
£18.18
Delivery:
Key features
  • A compact wireless mouse with high-definition tracking.
  • Contoured design
  • 1-year battery life
  • Logitech reliability
  • Logitech Advanced Optical Tracking
  • Logitech Unifying receiver
Product codes
The feel-good, reliable mouse with more precise navigation and soft rubber grips.
From surfing the web to updating your Facebook - you'll be mousing on more surfaces thanks to Logitech optical. No delays, dropouts or hassles. The plug-and-forget nano-receiver keeps you connected with reliable wireless.
Logitech® Advanced Optical Tracking
Enjoy precise clicking and pointing--on surfaces other optical mice can't handle--while navigating your favorite websites thanks to Logitech Advanced Optical Tracking.
Logitech Advanced 2.4 GHz wireless connectivity
You get the reliability of a cord with wireless convenience and freedom--fast data transmission and virtually no delays or dropouts.
1-year battery life
You can go for a year without battery hassles. An On/Off switch and smart sleep mode extend battery life, while an indicator light eliminates surprises
Plug-and-forget nano-receiver
So small and unobtrusive, you can plug it into a USB port and forget about it. Plus, you can say good-bye to worries about broken or lost receivers.
Compact comfort
You'll enjoy more comfort and ease thanks to this compact mouse's hand-friendly, contoured design with soft rubber grips and a smooth scroll wheel.
You get the high quality and reliability that have made Logitech the global leader for mice--plus a three-year limited hardware warranty.
Perfect for laptops and netbooks
Your mouse works with Windows®, Mac® and Linux®. No matter what type of computer you own today--or buy tomorrow--you can depend on your mouse to work like you expect.
Product Description Logitech M235 - mouse - 2.4 GHz - grey
Device Type Mouse
Connectivity Technology Wireless - 2.4 GHz
Colour Grey
Orientation Right-handed
Dimensions (WxDxH) 5.5 cm x 9.5 cm x 3.86 cm
Weight 84 g
Localisation Western Europe
Wireless Receiver USB wireless receiver
Movement Detection Technology Optical
Features Scrolling wheel, rubber side grips, battery indicator, on/off power switch
Battery 1 x AA type
OS Required Linux Kernel 2.6 or later, Microsoft Windows Vista / XP / 7, Apple MacOS X 10.5 or later
Microsoft Certification Compatible with Windows 7
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Logitech Wireless Mous...
£18.18
