Logitech Wireless Mouse M280 - Blue
Key features
  • Crafted for your hand
  • 18-month battery life
  • Smooth and precise tracking
  • Plug-and-forget Nano receiver
Product codes
Enjoy extra comfort for your right hand through curved grips made of soft rubber. Go longer between battery changes thanks to the energy efficient engineering. Plus, M280 automatically puts itself to sleep when you're not using it.
Get ultra precision and responsiveness with Logitech Advanced Optical Tracking. Plug it once and forget it. Nano receiver gives you a convenient and reliable wireless connectivity.
Product Description Logitech M280 - mouse - 2.4 GHz - blue
Device Type Mouse
Connectivity Technology Wireless - 2.4 GHz
Colour Blue
Orientation Right-handed
Dimensions (WxDxH) 6.79 cm x 10.54 cm x 3.84 cm
Weight 91 g
Wireless Receiver USB wireless receiver
Movement Detection Technology Optical
Buttons Qty 3
Movement Resolution 1000 dpi
Features Scrolling wheel, battery indicator, on/off power switch, Nano wireless receiver, auto sleep mode, Logitech Advanced Optical Tracking
Battery AA type
OS Required Linux Kernel 2.6 or later, Apple MacOS X 10.5 or later, Google Chrome OS, Microsoft Windows Vista / 7 / 8
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
