Logitech Z130 PC Multimedia Laptop Speakers - 5 Watt
£20.71
Delivery:
Key features
  • Get rich stereo sound in a small package. Simple to set up and control, these speakers make it easy to enjoy your music, movies and games.
  • Full Stereo Sound
  • Strong Bass
  • Easy Controls
  • Rich, clear sound
  • Easy setup
Product codes
Rich stereo sound
With five watts of total power, you get sound that's clear and strong.
Easy to control
It's a snap to get the sound you want with simple volume and power controls.
Built-in headphone jack
Plug in your headphones and listen to your music, movies and games where and when you want to.
Simple setup
Just connect the speakers to your laptop with a standard 3.5 mm plug and you're ready to go.
Product Description Logitech Z-130 - speakers - for PC
Product Type Speakers - for PC
System Components 2 speakers
Speaker Type Active
Nominal Output Power 5 Watt
Amplifier Integrated
Speaker System Details 2 2.5 Watt
Dimensions (WxDxH) 10.1 cm x 11 cm x 14.2 cm
Weight 0.59 kg
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Logitech Z130 PC Multi...
£20.71
