Logitech Z313 2.1 Channel Multimedia Speaker System - 25 Watt
£36.37
11 in stock
Delivery:
Standard: 1-3 working days
Key features
  • With a convenient control pod and big, balanced sound, this speaker system is the easy way to kick back with your music.
  • Rich Sound
  • Simple Setup
  • Easy Controls
  • Control at hand
  • Get down on it
  • Strike a pose
  • System Type: PC multimedia speaker system
  • Type: 2 speakers, Subwoofer
  • Power: 25Watt
  • Stock Status: In Stock
Product codes
Convenient control pod
Volume and power controls are within your reach with the wired control pod.
25 watts (RMS)
You've got enough power to fill your room with big, balanced sound.
Compact subwoofer
The compact, high-excursion subwoofer fits into tight spaces and delivers deeper bass when you want to feel the beat
Easy setup
You just connect the speakers to the subwoofer, and plug the subwoofer into your computer. That's it
Headphone jack
You can listen to your favorite tracks, play games, and watch videos in private.
Product Description Logitech Z-313 - speaker system - for PC
Product Type Speaker system - for PC - 2.1-channel
System Components 2 speakers, subwoofer
Speaker Type Active
Nominal Output Power (Total) 25 Watt
Audio System Max Output Power 50 Watt
Frequency Response 48 - 20000 Hz
Amplifier Integrated
Speaker System Details 2 , 1 x subwoofer
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Logitech Z313 2.1 Chan...
£36.37
