Maxtor 1TB M3 Portable USB3.0 External Hard Drive
£42.98
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Handy portable storage
  • Durable black design
  • SafetyKey protection for your data
Product codes
The Maxtor M3 portable external hard drive delivers handy portable storage. It is easy to take wherever you go, and has ample capacity. The durable black design stands up to the rigors of daily use.
What's in the box?
  • 1 x Maxtor M3 1Tb
  • USB 3.0 cable
  • Multi-language manual
Product Description Maxtor M3 STSHX-M101TCBM - hard drive - 1 TB - USB 3.0
Type Hard drive - external (portable)
Capacity 1 TB
Interface USB 3.0
Data Transfer Rate 5.0 Gbps (USB 3.0)
Features SafetyKey
Power Source USB bus
Enclosure Colour Black
Dimensions (WxDxH) 82 mm x 112 mm x 17.5 mm
Weight 151 g
Manufacturer Warranty 3 years warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Maxtor 1TB M3 Portable...
£42.98
