Maxtor 4TB M3 Portable USB3.0 External Hard Drive
£101.67
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Handy portable storage
  • Durable black design
  • SafetyKey protection for your data
  • Form Factor: 2.5"
  • Capacity: 4TB
  • Interface: USB 3.0
  • Stock Status: In Stock,
    Used stock also available below
Product codes
The Maxtor M3 portable external hard drive delivers handy portable storage. It is easy to take wherever you go, and has ample capacity. The durable black design stands up to the rigors of daily use.
What's in the box?
  • 1 x Maxtor M3 4Tb
  • USB 3.0 cable
  • Multi-language manual
Product Description Maxtor M3 STSHX-M401TCBM - hard drive - 4 TB - USB 3.0
Type Hard drive - external (portable)
Capacity 4 TB
Interface USB 3.0
Data Transfer Rate 5.0 Gbps (USB 3.0)
Enclosure Colour Black
Dimensions (WxDxH) 82 mm x 118.2 mm x 19.85 mm
Weight 236 g
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Customer return - item has been replaced under warranty by the manufacturer
Ref: C1RP 042451
£82.32
product
Ref: C1RP 042451
Accessories
Packaging
Functional
Software
Manuals
£82.32
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Maxtor 4TB M3 Portable...
£101.67
