Meta Quest 2 Carry Case
FREE DELIVERY
£59.98
10 in stock
Delivery:
Standard: 1-3 working days
Express: Delivered tomorrow
Express Delivery:
  • 00 h
  • 00 m
  • 00 s
Key features
  • Everything in its place
  • Safe storage
  • Contoured foam inner moulding absorbs rattles and bumps as you travel
  • Stock Status: In Stock
Product codes
Bring it with you or tuck it away. This lightweight case provides sturdy protection whether you're at home or on the go. The padded interior fits the Oculus Quest 2 headset.
The Quest 2 Carrying Case fits your headset, two controllers, a charge cable, power adaptor and either Elite Strap perfectly.
Safe storage
A dual shell outer casing keeps your Quest 2 system out of harm’s way.
Portable protection
Contoured foam inner moulding absorbs rattles and bumps as you travel.
Product Description Oculus Quest - case for virtual reality headset
Product Type Case for virtual reality headset
Designed For Oculus Quest 2 (256 GB), Quest 2 (64 GB)
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£59.98
