Upgrade your comfort and secure your headset in the perfect position for the clearest visuals, however much you move.
Enhance your comfort
Straps, bracing and an easily adjustable fit wheel work together for the perfect fit.
Stay in the sweet spot
Keep your headset in the right position for the best visuals, even as you move.
Got an old games console lying around?
When you trade in your old device at BT you can have the money transferred directly to your bank account - to offset your upgrade to the latest tech! Simply head to our Trade In site to find out more.
Product Description | Meta virtual reality headset strap | Product Type | Virtual reality headset strap | Dimensions (WxDxH) | 17.5 cm x 21.5 cm x 10.4 cm | Weight | 179 g | Designed For | Meta Quest 2 (256 GB), Quest 2 (64 GB) |
General | |
Dimensions (WxDxH) | 17.5 cm - 21.5 cm - 10.4 cm |
Weight | 179 g |
Shipping Dimensions (WxDxH) / Weight | 20.1 cm x 29.4 cm x 12.4 cm |
Compatibility Information | |
Customer return - item has been opened but is in excellent condition
Ref: GYP3 046735 |
Accessories | |
Packaging | |
Functional | |
Software | |
Manuals | |
£31.36
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
