Meta Quest 2 Elite Strap with Battery
FREE DELIVERY
£109.99
16 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Elite Strap With Battery
  • Extend your play time
  • Maximise your comfort
  • Seamless compatibility
  • Stock Status: In Stock
Product codes
Go all in with enhanced comfort and battery life. This ergonomic strap increases balance and support with a quick twist of the fit wheel. The built-in battery doubles your playtime, letting you stay focused from the first step to the final mission.
A built-in battery extends your play time between charges.
A balancing design uses battery weight to lift the headset away from your face for a lighter feel.
Engineered for use with official Meta Quest hardware and accessories (sold separately).
Product Description Oculus virtual reality headset strap
Product Type Virtual reality headset strap
Dimensions (WxDxH) 20 cm x 12 cm x 37 cm
Weight 179 g
Designed For Oculus Quest 2, Quest 2 (128 GB), Quest 2 (256 GB), Quest 2 (64 GB)
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£109.99
