Go all in with enhanced comfort and battery life. This ergonomic strap increases balance and support with a quick twist of the fit wheel. The built-in battery doubles your playtime, letting you stay focused from the first step to the final mission.
Extend your play time
A built-in battery extends your play time between charges.
Maximise your comfort
A balancing design uses battery weight to lift the headset away from your face for a lighter feel.
Seamless compatibility
Engineered for use with official Meta Quest hardware and accessories (sold separately).
Got an old games console lying around?
When you trade in your old device at BT you can have the money transferred directly to your bank account - to offset your upgrade to the latest tech! Simply head to our Trade In site to find out more.
Product Description | Meta virtual reality headset strap | Product Type | Virtual reality headset strap | Dimensions (WxDxH) | 20 cm x 12 cm x 37 cm | Weight | 179 g | Designed For | Meta Quest 2, Quest 2 (128 GB), Quest 2 (256 GB), Quest 2 (64 GB) |
General | |
Dimensions (WxDxH) | 20 cm - 12 cm - 37 cm |
Weight | 179 g |
Shipping Dimensions (WxDxH) / Weight | 29.4 cm x 20.1 cm x 12.4 cm |
Compatibility Information | |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
