Meta Quest 2 Fit Pack
FREE DELIVERY
£49.99
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Easy setup
  • Blazing fast performance
  • Games, fitness and more
  • Create play explore
  • 3D cinematic sound
  • Headset casting
  • Stock Status: In Stock
Product codes
Improve your fit and increase your immersion. Wide and narrow interfaces let you adjust your fit to suit your face. Snap-in light blockers give you the option of complete darkness for more vibrant VR visuals.
Your choice of fit
Alternate-sized facial interfaces accommodate wider and narrower fittings.
See better in the dark
Fit Pack’s light blockers give you a more vibrant visual experience.
Product Description Oculus Quest 2 - virtual reality headset face cushion kit
Product Type Virtual reality headset face cushion kit
Package Content Light blocker, 2 facial interfaces
Dimensions (WxDxH) 10.4 cm x 16.3 cm x 2.4 cm
Weight 87 g
Designed For Oculus Quest 2, Quest 2 (128 GB), Quest 2 (256 GB), Quest 2 (64 GB)
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£49.99
