Meta Quest 2 Link Cable
FREE DELIVERY
£89.98
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • 5-meter headset cable
  • Support for SuperSpeed USB ports
  • TPU 0.5mm thickness, optimized for low friction, durability, and flexibility
  • High-quality spiral shielding doubling as grounding
  • Stock Status: In Stock
Product codes
Play the best of both worlds with Oculus Link high-speed fiber optic cable that connects your compatible gaming PC to the all-in-one Oculus Quest headset. Its lightweight, flexible design empowers you to take on a wide range of games from the action-packed Oculus Rift library.
Expand your library
Connect to over 1,000 PC-based VR titles in the Rift library.
Move with freedom
This ultra-long, ultra-fast, flexible fibre-optic cable is designed for VR.
Product Description Oculus Link - virtual reality headset cable - USB-C to USB-C - 5 m
Type Virtual reality headset cable
Technology Double shielded/fibre optic
Features 5 Gbps data rate
Length 5 m
Connector 24 pin USB-C - male - right-angled
Connector (Second End) 24 pin USB-C - male - straight
Rated Current 3 A
Compliant Standards USB 3.2 Gen 1
Colour Black
Designed For Oculus Quest, Quest 128GB, Quest 2, Quest 2 (128 GB), Quest 2 (256 GB), Quest 2 (64 GB), Quest 64GB
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£89.98
