Experience the Arc Touch Mouse: there is no equal in look, feel, and performance. With a dramatic design and easy elegance, this stylish mouse is a perfect fit for your lifestyle. Flick to zip down the page. Tap to stay at your destination. Feel the speed and responsiveness to your touch.
Product Description | Microsoft Arc Touch Mouse - mouse - 2.4 GHz - black | Device Type | Mouse | Connectivity Technology | Wireless - 2.4 GHz | Colour | Black | Orientation | Right and left-handed | Dimensions (WxDxH) | 5.88 cm x 13 cm x 1.5 cm | Weight | 88 g | Wireless Receiver | USB wireless receiver | Movement Detection Technology | Optical | Buttons Qty | 2 | Movement Resolution | 1000 dpi | Performance | 8000 fps, up to 72 inches per second | Features | Touch-sensitive scroll, on/off power switch, Microsoft BlueTrack Technology, Nano wireless receiver | Battery | 2 x AAA type | OS Required | Microsoft Windows Vista / XP / 7 | Microsoft Certification | Compatible with Windows 7 | Manufacturer Warranty | 3-year warranty |
General | |
Width | 5.88 cm |
Depth | 13 cm |
Height | 1.5 cm |
Weight | 88 g |
Colour | Black |
Input Device | |
Connectivity Technology | Wireless |
Interface | 2.4 GHz |
Buttons Qty | 2 |
Expansion / Connectivity | |
Interfaces | 1 x USB - 4 pin USB Type A |
Miscellaneous | |
Compatible with Windows 7 | "Compatible with Windows 7" software and devices carry Microsoft’s assurance that these products have passed tests for compatibility and reliability with 32-bit and 64-bit Windows 7. |
Compliant Standards | USB 2.0 |
Battery | |
Type | AAA type |
Technology | Alkaline |
Installed Qty | 2 |
Run Time (Up To) | 6 months |
Software / System Requirements | |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 5 - 80% (non-condensing) |
