Microsoft Sculpt Comfort Desktop
£64.72
Delivery:
Key features
  • Maximum comfort, customized for you
  • Modern modular design
  • Windows 8 integration
Product codes
With its contoured design, customizable features that easily adjust to your needs, and a specially designed, right-handed mouse, Sculpt Comfort Desktop transforms the way you use a keyboard and mouse. It helps you keep your wrists in a neutral position, while providing functionality and shortcuts that improve typing efficiency.
The sleek design and comfort curve layout keep keys within easy reach, while straightening wrists with ergonomic palm support that protects against inflammation and repetitive stress injuries. The split spacebar offers new backspace functionality to help you make the most of your keystrokes. Tight workspace? Sculpt Comfort Desktop can be easily customized to save space, and offer a more compact look, by detaching the palm rest.
Sculpt Comfort Desktop perfectly integrates with Windows 8. The keyboard hotkeys provide shortcuts to the most commonly used keyboard functions. The Windows Touch tab, a touch-sensitive strip located on the side of the mouse, enables you to take advantage of swiping functionality as you navigate the Start screen.
Product Description Microsoft Sculpt Comfort Desktop - keyboard and mouse set - UK
Device Type Keyboard and mouse set - ergonomic
Interface 2.4 GHz
Wireless Receiver USB wireless receiver
Input Device Keyboard
Connectivity Technology Wireless
Localization and Layout UK
Keys Qty 105
Hot Keys Function Calculator, volume, search, mute, play/pause
Features Removable palm rest, battery LED indicator, split spacebar with backspace functionality
Pointing Device Mouse - optical
Buttons Qty 3
Features Scrolling wheel (4-way), BlueTrack Technology, right-handed, Windows touch tab
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Microsoft Sculpt Comfo...
£64.72
