Microsoft Sculpt Comfort Mouse - optical - 3 button - wireles...
Microsoft Sculpt Comfort Mouse - optical - 3 button - wireless - Bluetooth - black
Designed for comfort and function, plus stay connected on the go
£31.14
39 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Bring order to your busy days
  • Stay connected on the go
  • Type: Mouse
  • Wired / Wireless: Wireless
  • Colour: Black
  • Compatibility: Android, Mac, PC
  • Stock Status: In Stock
Product codes
Access your favorite Windows features—faster and easier
The Sculpt Comfort Mouse, with the blue Windows touch tab, lets you access Windows apps and the Start screen quickly and easily. Designed for comfort and function, it works with most Android tablets on virtually any surface.
The ultimate Windows mouse
The blue Windows touch tab on Sculpt Comfort Mouse revolutionizes the relationship between hardware and software, providing quick and easy access to your favorite Windows 8 features. Quickly navigate to the Start screen and access apps faster. Press the center of the sleek blue tab to switch between your current app and the Start screen. Or simply swipe up on the tab to cycle through all of your open apps, or down to reveal all the open apps and select the one you want.
The ease and speed of the Windows touch tab means you can get things done with precision and effortless control. Plus, Sculpt Comfort Mouse's intuitive, modern design and high functionality make it the perfect complement to your Windows 8 experience.
Sculpt Comfort Mouse features Bluetooth connectivity, so you can easily pair your device with your PC or tablet and not worry about using cords or transceivers. As well, its BlueTrack technology works on virtually any surface. The right-handed thumb scoop design and Tilt wheel allow you to quickly and comfortably scroll left, right, up and down.
Scooped Right Thumb for Comfort Grip
Ergonomic design for right-handed users makes extended use more comfortable.
Four-Way Scrolling
Scroll four ways for greater efficiency and comfort by using the tilt wheel.
Compatibility
Windows 7
Windows 8
Windows RT
iOS 4
iOS 5
Android 3.2 & above
Product Description Microsoft Sculpt Comfort Mouse - mouse - Bluetooth 3.0 - black
Device Type Mouse
Connectivity Technology Wireless - Bluetooth 3.0
Colour Black
Orientation Right-handed
Dimensions (WxDxH) 6.85 cm x 11.1 cm x 3.65 cm
Weight 136 g
Movement Detection Technology Optical
Buttons Qty 6
Movement Resolution 1000 ppi
Performance 8000 fps, up to 72 inches per second
Features Scrolling wheel (4-way), Microsoft BlueTrack Technology
Battery 2 x AA type
OS Required Microsoft Windows 7, Windows 8, Microsoft Windows RT, Apple MacOS X 10.6 - 10.8
Microsoft Certification Compatible with Windows 7
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Microsoft Sculpt Comfo...
£31.14
