Microsoft Sculpt Ergonomic Wireless Keyboard and Keypad Set
£77.91
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Unique design for comfort and functionality
  • Protection for your joints
  • Following the KeySellingPoints's natural lines
  • Recommended Use: Leisure, Office
  • Type: Keyboard, Keypad
  • Wired / Wireless: Wireless
  • Compatibility: Mac, PC
  • Stock Status: In Stock,
    Used stock also available below
Product codes
Bundle deals (1)
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £81.40
Save £1.50
With its modern, ergonomic design, Sculpt Ergonomic Keyboard sets the standard for support and comfort. It keeps your hands and arms in a relaxed position as you work, helping you feel refreshed after a day at your desk without soreness or injury.
Sculpt Ergonomic Keyboard is built on advanced ergonomic principles, with a split keyboard layout that keeps wrists and forearms in a relaxed position, and a cushioned palm rest that protects against inflammation and repetitive stress injuries. The domed keyboard shape works to reduce and correct excessive wrist pronation that can cause pain and limited mobility.
The natural arc layout follows the curve of your fingertips for a more natural way of typing. The reverse-tilt design positions the keyboard at the correct angle to give you a neutral wrist position.
Product Description Microsoft Sculpt Ergonomic Keyboard For Business - keyboard and keypad set - UK
Device Type Keyboard and keypad set - ergonomic
Interface 2.4 GHz
Wireless Receiver USB wireless receiver
Input Device Keyboard
Connectivity Technology Wireless
Localization and Layout UK
Keys Qty 105
Hot Keys Function Volume, mute, play/pause
Features Split spacebar with backspace functionality
Pointing Device Keypad
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Customer return - item has been used and shows signs of use
Ref: 9267 042674
£50.98
product
Ref: 9267 042674
Accessories
Packaging
Functional
Software
Manuals
£50.98
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Microsoft Sculpt Ergon...
£77.91
