With its modern, ergonomic design, Sculpt Ergonomic Keyboard sets the standard for support and comfort. It keeps your hands and arms in a relaxed position as you work, helping you feel refreshed after a day at your desk without soreness or injury.
Sculpt Ergonomic Keyboard is built on advanced ergonomic principles, with a split keyboard layout that keeps wrists and forearms in a relaxed position, and a cushioned palm rest that protects against inflammation and repetitive stress injuries. The domed keyboard shape works to reduce and correct excessive wrist pronation that can cause pain and limited mobility.
The natural arc layout follows the curve of your fingertips for a more natural way of typing. The reverse-tilt design positions the keyboard at the correct angle to give you a neutral wrist position.
Product Description | Microsoft Sculpt Ergonomic Keyboard For Business - keyboard and keypad set - UK | Device Type | Keyboard and keypad set - ergonomic | Interface | 2.4 GHz | Wireless Receiver | USB wireless receiver | Input Device | Keyboard - wireless | Layout | UK | Keys Qty | 105 | Hot Keys Function | Volume, mute, play/pause | Features | Split spacebar with backspace functionality | Pointing Device | Keypad | Manufacturer Warranty | 3-year warranty |
General | |
Max Operating Distance | Up to 3 m |
Dimensions (WxDxH) / Weight | Keyboard: 39.2 cm x 22.8 cm x 5.9 cm / 836 g , Keypad: 9.28 cm x 13.2 cm x 1.17 cm / 100 g |
Input Device | |
Type | Keyboard - wireless |
Keys Qty | 105 |
Layout | UK |
Pointing Device | |
Type | Keypad |
Miscellaneous | |
Compliant Standards | UL, VCCI, BSMI, ISO 9001, GOST, cUL, ISO 14001, CB, RSS-210, MIC, NTRA, KCC, WEEE, ANATEL, TELEC, URSEC, REACH, UkrSEPRO |
Software & System Requirements | |
OS Required | Microsoft Windows 7, Windows 8, Microsoft Windows RT |
Battery | |
Type | AAA type |
Installed Qty | 2 |
Required Qty | 2 |
Technology | Alkaline |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 5 - 80% (non-condensing) |
