Microsoft Wired Desktop 600 Black
£17.07
Delivery:
Key features
  • Comfort for either hand
  • Scroll wheel
  • Spill-resistant design
  • Optical technology
  • Quiet Touch keys
  • Media centre
Product codes
This desktop set combines a spill-resistant keyboard and optical mouse to deliver all the features you need-and more-with Microsoft quality and reliability. Enjoy plug-and-play setup, Windows Vista integration, Quiet Touch keys with quick access to media controls and calculator, and a comfortable ambidextrous mouse.
Mouse Features:
  • Windows Start Button: Press to launch your Start menu and search your PC or the Web if you have Windows Vista installed
  • Plug and Play: No software needed. Just connect the keyboard to your PC and go!
  • Comfort for Either Hand: Use your mouse with your left or right hand--ambidextrous design makes it comfortable either way
  • Optical Technology: Navigate with better speed, accuracy and reliability--the optical sensor tracks movement on nearly any surface without the hassle of clogged mouse parts
  • Scroll Wheel: Move through your documents quickly without having to click on the on-screen scroll bar
Keyboard Features:
  • Media Center: Four hot keys let you control the most-used media activities (play/pause, volume up, volume down, and mute)
  • Quiet-touch Keys: Quiet, responsive, thin-profile keys
  • Calculator Hot Key: With the touch of the button, you can quickly access the Calculator
  • Spill-Resistant Design: Enjoy a drink while you work--this keyboard is designed to withstand an accidental spill
  • Warranty: 3-Year Limited Hardware Warranty
Product Description Microsoft Wired Desktop 600 - keyboard and mouse set - English - United Kingdom - black
Device Type Keyboard and mouse set
Interface USB
Input Device Keyboard
Connectivity Technology Wired
Localization and Layout English - United Kingdom
Hot Keys Function Multimedia, calculator, volume, mute
Features Spillproof
Pointing Device Mouse - optical
Colour Black
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Microsoft Wired Deskto...
£17.07
