Microsoft Wireless Mobile Mouse 1850 (Purple)
£12.45
10 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Scroll wheel
  • Comfort and portability
  • Plug-and-go nano transceiver
  • Comfortable in either hand
  • Wired / Wireless: Wireless
  • Colour: Pantone purple
  • Compatibility: Android, Mac, PC
Product codes
The Wireless Mobile Mouse 1850 is designed for life on the go, offering wireless freedom and built-in transceiver storage for ultimate mobility. Comfortable to use with either hand and a scroll wheel for easy navigation makes this mouse the ideal device for your modern, mobile lifestyle.
This Microsoft mouse has a plug-and-go nano transceiver which plugs into a USB port, enabling wireless usage at home or on the go. All you have to do is plug it in and it's ready for use with no installation required.
The 1850 Mouse runs off one AA battery for up to six months, providing long-lasting use before it needs replacing.
With three programmable buttons, including a scrolling wheel, you can navigate your laptop or desktop with ease when using the Microsoft Wireless Mobile Mouse 1850.
Product Description Microsoft Wireless Mobile Mouse 1850 - mouse - 2.4 GHz - pantone purple
Device Type Mouse
Connectivity Technology Wireless - 2.4 GHz
Colour Pantone purple
Orientation Right and left-handed
Dimensions (WxDxH) 5.81 cm x 10 cm x 3.82 cm
Weight 90 g
Wireless Receiver USB wireless receiver
Movement Detection Technology Optical
Buttons Qty 3
Performance 3000 fps, up to 20 inches per second, 1000 points per inch
Features Scrolling wheel, Nano wireless receiver
Battery AA type
OS Required Microsoft Windows 7, Android 3.2 (Honeycomb), Windows 8, Android 4.2 (Jelly Bean), Windows 8.1 RT, Windows 8.1, Windows RT, Apple MacOS X 10.7 - 10.9, Windows 10
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£12.45
