Microsoft Wireless Mobile Mouse 3500 - Cyan Blue Gloss
£23.07
Colours:
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • BlueTrack technology
  • Plug-and-go nano transceiver
  • On/off switch
  • Comfortable in either hand
  • Type: Mouse
  • Wired / Wireless: Wireless
  • Colour: Cyan blue
  • Compatibility: PC
  • Stock Status: In Stock
Product codes
Bundle deals (1)
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £26.56
Save £1.50
Keep moving with a transceiver that stays in your mobile PC when you go and a mouse that works on more surfaces with Microsoft BlueTrack technology!
Product Description Microsoft Wireless Mobile Mouse 3500 - mouse - 2.4 GHz - cyan blue
Device Type Mouse
Connectivity Technology Wireless - 2.4 GHz
Colour Cyan blue
Orientation Right and left-handed
Dimensions (WxDxH) 5.7 cm x 9.5 cm x 4 cm
Weight 90 g
Wireless Receiver USB wireless receiver
Movement Detection Technology Optical
Buttons Qty 3
Movement Resolution 1000 dpi
Performance 8000 fps
Features Scrolling wheel, rubber side grips, battery indicator, on/off power switch, Microsoft BlueTrack Technology
Battery 1 x AA type
OS Required Microsoft Windows 7, Windows 8, Microsoft Windows RT, Windows 8.1
Microsoft Certification Compatible with Windows 7
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Microsoft Wireless Mob...
£23.07
