Microsoft Wireless Mobile Mouse 3500 (Flame Red Gloss)
£20.74
Colours:
33 in stock
Delivery:
Standard: 1-3 working days
Key features
  • BlueTrack technology
  • Plug-and-go nano transceiver
  • On/off switch
  • Comfortable in either hand
Product codes
Keep moving with a transceiver that stays in your mobile PC when you go and a mouse that works on more surfaces with Microsoft BlueTrack technology!
BlueTrack Technology
Take advantage of BlueTrack Technology, which combines the power of optical with the precision of laser for remarkable tracking on virtually any surface.
Plug-And-Go Nano Transceiver
Leave the Nano Transceiver plugged in when you're on the go, or stow it in the mouse.
8-Month Battery Life
Use your mouse for up to eight months without having to change batteries. Battery status indicator tells you when battery power is low.
On/Off Switch
Conserve battery power by turning off your mouse when not in use.
Comfortable in Either Hand
Use your mouse with your left or right hand. Ambidextrous design makes it comfortable either way.
Microsoft Wireless Mobile Mouse 3500 - mouse - 2.4 GHz - flame red gloss
Mouse
Wireless - 2.4 GHz
Flame red gloss
Orientation
Right and left-handed
5.7 cm x 9.5 cm x 4 cm
90 g
Wireless Receiver
USB wireless receiver
Movement Detection Technology
Optical
Buttons Qty
3
Movement Resolution
1000 dpi
Performance
8000 fps
Scrolling wheel, rubber side grips, battery indicator, on/off power switch, Microsoft BlueTrack Technology
1 x AA type
Microsoft Windows 7, Windows 8, Microsoft Windows RT, Windows 8.1
Microsoft Certification
Compatible with Windows 7
3 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Microsoft Wireless Mob...
£20.74
