You'll appreciate how this wireless mobile mouse comfortably fits your hand and your mobile lifestyle. Use it just about anywhere, even on a rough park bench or your living room carpet, relying on Microsoft BlueTrack Technology.
When it's time to pack up and go, you'll hardly notice the tiny transceiver. Keep it plugged into the USB port, or stow it in the bottom of the mouse for travel. Keep using your mouse for up to eight months with a single battery, and rely on the power indicator to tell you when it's time to replace it.
Take advantage of BlueTrack Technology, which combines the power of optical with the precision of laser for remarkable tracking on virtually any surface.
Plug-And-Go Nano Transceiver
Leave the Nano Transceiver plugged in when you're on the go, or stow it in the mouse.
8-Month Battery Life
Use your mouse for up to eight months without having to change batteries. Battery status indicator tells you when battery power is low.
On/Off Switch
Conserve battery power by turning off your mouse when not in use.
Comfortable in Either Hand
Use your mouse with your left or right hand. Ambidextrous design makes it comfortable either way.
Product Description | Microsoft Wireless Mobile Mouse 3500 for Business - mouse - 2.4 GHz - lochness grey | Device Type | Mouse | Connectivity Technology | Wireless - 2.4 GHz | Colour | Lochness grey | Orientation | Right and left-handed | Wireless Receiver | USB wireless receiver | Movement Detection Technology | Optical | Buttons Qty | 3 | Movement Resolution | 1000 dpi | Features | Scrolling wheel, rubber side grips, battery indicator, on/off power switch, Microsoft BlueTrack Technology | OS Required | Microsoft Windows 7, Windows 8, Microsoft Windows RT, Windows 8.1 | Manufacturer Warranty | 3-year warranty |
General | |
Input Device | |
Connectivity Technology | Wireless |
Interface | 2.4 GHz |
Max Operating Distance | Up to 10 m |
Buttons Qty | 3 |
Expansion / Connectivity | |
Interfaces | 1 x USB - 4 pin USB Type A |
Software / System Requirements | |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
